2020.1.1 Update install location grayed
Why am I not able to change install location when running (as admin) the 2020.1.1 update. The option (default location shown) is grayed out
It’s a known issue in the current installer. The work around for now is to uninstall 2020.1 and then install 2020.1.1.
I realized I should qualify this a bit. The problem case is where you had previously installed in a non-C drive, the installer doesn’t pick up on that. If it did pick up on it, the install location would still not be editable, but it would at least point to the right installation folder.
Thanks, will take the uninstall work around suggested. My SketchUp and AutoCAD installs are on a separate physical SSD drive assigned K:
