If I make a cylinder, the wrap of a picture works fine. But if I first make a number of holes (windows of a tower) in the cylinder and then wrap it, the picture is very irregular and segmented.
Thanks for you quick answer. I tried your suggestion but it resulted in the same mesh. I solved the issue with Thru-Paint by Fredo 6.
Apparently you didn’t do what I wrote or it would have worked as I showed in my screen shot.
Good enough but it doesn’t require an extension.
You’re right. No need for Fredo. I misinterpreted your solution. Forgot Projection etc.
