I wish you could make calculations while you input dimensions etc. (ex; length: =1000mm-18mm)
I wish they add SVG import. Now I’m able to do it with a plugin, but this should be standard. It works so good in combination with for example Affinity Designer (Afinity 2.4. has now DWG export!)
*** I wish they placed material names below the material color icon (my goodness);**
I wish they placed component names below the component icons
I wish they would upgrade the dimensioning tools with more options (edit leaders, angular dim. etc);
I wish the standard scale tool can actually scale(!) (like Fredo);
I wish the isolate(!) tool becomes standard;
I wish for snapping to midpoints of faces;
I wish SU is snappy again!
I wish, wish, wish for section-cut materials (added in the material section as second material) and texture-size saved for each scene**(!)** (how simple is this);
I wish moving color sliders and dragging layers in Lay Out will go smoother;
I wish single line text (like Curic’s plugin) was standard in SU.
(ps: AI is great but finish SU & LAYOUT(!!!) first!)
