VER = '1.0'
e = SketchupExtension.new( 'ABC', './core.rb')
e.version = VER
set extension.version with a variable like this cause sketchup 23-24 drop loading the code without warning, anyone knows why ?
VER = '1.0'
e.version = VER
I cant test your case right now, but I noticed something else:
When you create a new SketchupExtension object, the path should be pointing to a file in a support folder (with the same name as root RB file, excluding the .rb extension).
In your example the core.rb suposed to be a same folder as the root rb.
I guess it should be something like:
e = SketchupExtension.new( 'ABC', 'abc/core.rb')
It is also recommended to omit the file extension provided in the path argument. (SketchUp will resolve the file extension to .rbe, .rbs or .rb), so it is better like this:
e = SketchupExtension.new( 'ABC', 'abc/core')
Do not define constants in the top-level ObjectSpace. Define them within the extension submodule that must be wrapped inside your own namespace module.
Ie …
# Registrar File: "Plugins/ZhouSiFu_abc.rb"
module ZhouSiFu
module ABC
VERSION = '1.0.0'
EXTENSION = SketchupExtension.new('ZhouSiFu: ABC', 'ZhouSiFu_abc/core')
EXTENSION.version = VERSION
# ... set other porperties ...
Sketchup.register_extension(EXTENSION, true)
end
end
# Loader File: "Plugins/ZhouSiFu_abc/core.rb"
module ZhouSiFu
module ABC
# ... core code, etc ...
end
end
