I get this error when testing out my extension in sketchup 2015:
Error Loading File C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin/archvision_plugin.rb
Error: #<LoadError: cannot load such file -- test_projects.so>
C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin/archvision_plugin.rb:37:in `execute'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin/archvision_plugin.rb:57:in `<module:ArchVisionRubyExtension>'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin/archvision_plugin.rb:20:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `load'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin_extension.rb:15:in `register_extension'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin_extension.rb:15:in `<module:ArchVisionRubyExtension>'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin_extension.rb:7:in `<module:ArchVision>'
C:/Users/ewilcox/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/archvision_plugin_extension.rb:6:in `<top (required)>'
This is the code in Ruby. My extension is written in c++
I first check if the file exists, because i thought that might of been my problem but when I open sketchup the message box “Exists” pops up and then I get this error.
if (File.exist?("C://Users//ewilcox//AppData//Roaming//SketchUp//SketchUp\ 2015//SketchUp//Plugins//archvision_plugin//test_projects//x64//Debug//test_projects.so"))
UI.messagebox("Exists")
require 'test_projects.so'
