Why is my model not a solid?
Unfortunately. I cant get put some windows on the curved surface. I made it into a group but it still says not a solid. A little help pls? I use sketchup for web so I dont have any extensions to check
Split Concept (Updated).skp (417.8 KB)
In order to be considered a solid every edge must be shared by exactly two faces. The “floors” in your model have no thickness so those edges don’t meet the two faces requirement.
Erase the bottom faces and any remaining edges. Also reverse the face on the bottom of the walls. There should be no exposed blue back faces. After that the group will be a solid.
What version of SketchUp are you using? There is no Free Plan 0f SketchUp 2023. Or are you using a cracked version?
What operating system? 23 is not an operating system. What graphics card? 233 does not identify a graphics card.
I just typed in some random stuff right quick as I was making my account, I changed it to what my actual operating system and graphics card is. Also, I’m using the Sketchup web version. However, I’m still not getting a solid even after making those changes
Split Concept (Updated)(1).skp (435.0 KB)
:roll_eyes:
So it was faster to put in bogus information and then go back and edit it later?
There’s still a stray edge that needs deleting.
Thank you for the help, I really appreciate it!
