Why can't I see SKP in mobile even after buying Sketchup for web
Why its still showing like that… I just purchased Skexthup for web and still can’t see :smiling_face_with_tear::smiling_face_with_tear:
There must be a problem with the file, if you want you can share it and I can check if it opens on the desktop version.
hello,
the mobile viewer isn’t depending on any subscription, it just hasn’t been updated since september 2024. Any file created with 2024&2025 version won’t open, nor files created with sketchup for web.
and since you can’t officially save to older versions…
There any way i can open my file in my phone?
baramati.stl (264.3 KB)
baramati.skp (271.9 KB)
Can u please try sirr
I could open your file without any issues, I fixed it a bit, since you have an stl I guess you want to print it so you must have solid groups, you had two tags but those were assigned to loose geometry so when I ran Cleanup3 it removed the tags from the geometry and deleted them since they weren´t been used on the model, anyways you can create them again and assign just to groups or components.
baramati.skp (275.0 KB)
OP wants to open his model on a phone with the viewer
@RAika28 try this one, it should open fine on your phone.
baramati-v_2018.skp (515.9 KB)
Thank ypu so much, how you guys did?
Thank you so much❤
I used a desktop version to save as an old version that the viewer is able to open
Oh, in web version we can’t do right?? Can you help me again​:smiling_face_with_tear::smiling_face_with_tear:? :slightly_smiling_face::slightly_smiling_face:if i need help? For make low version?.. Please :pleading_face::pleading_face::pleading_face:
Sure, but not today :innocent:
