Whenever i export skp to cad dwg, the dwg file doesnt show any lines
hi! last last week i exported an isometric skp file to dwg cad file and it worked. however today its not working. i dont know whats happening or if i accidentally switched something for it to not work. theres no prompt saying stuff, it just loads after exporting, then when ill open the cad dwg file, theres no lines. can anyone help me with this problemm? thank u!
You could upload the.skp file for others to investigate..
If it’s bigger than 15Mb you can use a file sharing service and share the link here.
Hello, many times the generated CAD dwg file is displaced in the field of view or at a barely visible scale; I suggest that when you open the file in cad, go to the menu VIEW>ZOOM>ALL
Normally the file appears there.
I hope it works
