What's the right way to extrude this shape?
Hi everybody
I want to extrude this shape 15 units along green axe and 20 units along blue axis.
question
What I get is a internal face that I only know how to delete with lot of extra steps.
try
Any recommendation?
This is the file: CADAvaDes11.skp (38.8 KB)
Thanks in advance.
I think you are doing it the only way you can. No way to avoid the internal face. Just draw a new line across the junction of the vertical and horizontal faces to separate the hidden face the delete the unneeded edges.
After the second Push/Pull operation, select all of the geometry. Right click on it and choose Intersect Faces>With Selection. Then erase the edges on the faces.
Frankly, I would probably not draw the bottom part of the bracket until the upper part is completed and avoid creating any internal faces or coplanar edges to deal with at all.
Thank you so much guys :wink:
It worked like a charm.
