for example : FreeCAD program used ifcopenshell to do this operation , is sketchup uses something like ifcopenshell to export or import ifc file ??
You need to use Sketchup Pro to be able to import/export ifc.
okey… any part of sketchup pro is responsible to do this operation ,
if any APIs or modules in sketchup can i using to make some extension
The only exposure for IFC import is the Sketchup::Model#import() method …
model = Sketchup.active_model
show_summary = true
filepath = UI.openpanel("Choose IFC file ...","*.ifc")
return unless filepath
status = model.import(filepath, show_summary)
SketchUp API Importer Options: IFC
Industry Foundation Classes (IFC)
- No options are supported for this type on import.
The only exposure for IFC export is the Sketchup::Model#export() method …
if Sketchup.active_model.title.empty?
filename = "Untitled"
else
filename = Sketchup.active_model.title
end
filepath = UI.savepanel(
"Choose IFC filename and location ...",
"#{filename}.ifc"
status = model.export(
filepath,
:hidden_geometry => true,
:doublesided_faces => false,
:ifc_mapped_items => true,
:ifc_types => [ "IfcProject","IfcSite","IfcBuilding","IfcBuildingElementProxy" ]
SketchUp API Exporter Options: IFC
:hidden_geometry- Boolean to indicate whether to export hidden geometry.:doublesided_faces- Boolean to indicate whether to export 2-sided faces.:ifc_mapped_items- Boolean to indicate whether to export IFC mapped items.:ifc types- An Array of strings indicating IFC elements to export. One or more of the following values can be in the array.
- values:
"IfcNonDefined", "IfcBeam", "IfcBuilding", "IfcBuildingElementProxy", "IfcBuildingStorey", "IfcColumn", "IfcCurtainWall", "IfcDoor", "IfcFooting", "IfcFurnishingElement", "IfcMember", "IfcPile", "IfcPlate", "IfcProject", "IfcRailing", "IfcRamp", "IfcRampFlight", "IfcRoof", "IfcSite", "IfcSlab", "IfcSpace", "IfcStair", "IfcStairFlight", "IfcWall", "IfcWallStandardCase", "IfcWindow"
Also check this:
