What does an ! in a yellow triangle mean?
That’s a long time ago. :slight_smile: I think we sorted it before but I don’t remember. Can you share the LayOut file? By private message if you wish.
8944 Campo Road R3 6’ Wall.layout (3.0 MB)
Dave I uploaded the file. I hope that you can access it.
Thanks,
Calvin
Got it. I’m not seeing any yellow triangles, though. I wonder if it has to do with the file locations for the SKP files. Looking at your file here, I’m looking at the embedded copies of the files not your working files. Try the following:
Go to File>Document Setup>References. Look at the SKP file references. What do they show for Status? Can you select them and choose Update? Does that fix the triangles?
I have to go out for a little while but I’ll be back.
Thanks,
I was able to relink to an original file and that took care of it.
Dave R,
Can you help me with ‘! in the yellow triangle’?
443 C 004.layout (7.0 MB)
I don’t see a yellow triangle on any of the viewports when I open your LayOut file. Which viewport is giving you trouble?
I do see some incorrect tag usage in your SketchUp file.
Screenshot - 1_3_2024 , 9_01_34 AM
What version of SketchUp are you using now? Your profile says 2019. Is that correct?
