What 2-in-1 Tablets are best for SketchUp?
Looking for Tablet that can run SketchUp
You will need a tablet that is a full computer, has an Intel processor and runs the full desktop version of Windows.
Anssi
According the the specs you will be fine with a desktop Mac. You should be able use an iPad with a Disto E7500i, but I’m not finding a direct way to import into SketchUp from there. Anybody?
I’m not sure I’m following your suggestion pedicini.
I’ll follow up on Anssi’s correct post with more specifics:
SketchUp is a Desktop application requiring a full Desktop operating system, specifically Microsoft Windows 7 or newer, or OS X 10.7 or newer.
If you wish to use SketchUp on a Tablet, the only thing going are the Windows based touchscreen laptops such as the Microsoft Surface Pro (but not the regular Surface.)
We do offer the SketchUp Mobile Viewer on iOS and Android which syncs with our 3D Warehouse and allows you to easily view your models on a tablet, there is no edit functionality in this mobile app.
To learn more about the Mobile viewers visit the app store for your device (Apple App Store, Google Play) and search for [SketchUp Mobile Viewer].
To learn system requirements for the Desktop version of SketchUp visit our site here: SketchUp Hardware and Software Requirements | SketchUp Help
an cheaper alternative to the MS Surface Pro could be the Dell Venue 11 Pro.
Why not the regular Surface? It has a touch screen and Windows just like the Surface Pro.
I am looking into getting a tablet and am curious why one works over the other.
  • Surface 3 Technical Specs
    Basically uses an cheap(~50$) junky embedded / phone quality CPU called Intel Atom x7.
    It only has the basic Intel HD embedded graphics, which are likely not 3D quality.
  • Surface Pro 3 Technical Specs
    Options let you choose from all 3 series of Intel® Core™ 4th generation mobile CPUs, with 4th generation HD graphics, ie: HD4200 (i3), HD4400 (i5), HD5000 (i7) respectively.
NOTE: The above links are obsolete (and have been removed) as the Microsoft Store no longer sells the old Surface 3 series. The following link is to the MS Support site:
Current offerings as of JAN 2022:
  • Surface Go 3
    • RAM: 4GB or 8GB (LPDDR3)
    • Storage: 64GB (eMMC) w/ Pentium or 128GB (SSD) w/ Core i3
    • CPUs: Dual-core Intel®
      • Pentium® Gold 6500Y processor
      • 10th Gen Core™ i3-10100Y processor
    • GPU: Intel® UHD Graphics 615 (integrated - shares system RAM)
    • DISPLAY:
      • Screen: 10.5” PixelSense™ Display
      • Resolution: 1920 x 1280 (220 PPI)
    • Connect: Built-in WiFi, plus optional LTE Advanced
    • OS:
      • Consumer: Windows 11 Home in S mode*
      • Business: Windows 10 Pro or Windows 11 Pro
* NOTE: To run desktop SketchUp with Ruby extensions, you will need to switch the OS permanently out of S mode. Otherwise you would be limited to running only Windows Store Apps and so only the SketchUp web editions within a browser.
Surface Pro X will NOT run x86 compiled SketchUp 64bit builds!
It cannot run the 2016 M1 32bit x86 compiled build under emulation,
as SketchUp requires OpenGL support which Adreno graphics do not.
Surface Pro X machines will be limited to running SketchUp for Web editions in a browser.
  • Surface Pro X
    • RAM: 8GB or 16GB (LPDDR4x)
    • SSD: 128GB, 256GB, 512GB or 1TB
    • CPU: ARM64 based SoC
      • Microsoft SQ® 1 (Qualcomm)
      • Microsoft SQ® 2 (Qualcomm)
    • GPU: (integrated - shares system RAM)
      • Microsoft (Qualcomm) Adreno™ 685 GPU
      • Microsoft (Qualcomm) Adreno™ 690 GPU
    • DISPLAY:
      • Screen: 13” PixelSense™ Display
      • Resolution: 2880x1920 (267 PPI)
    • Connect: choose Wi-Fi or optional Gigibit LTE
    • OS:
      • with only Wi-Fi: Windows 11 Home on ARM
      • with opt. LTE: Windows 10 Home on ARM (upgrade to Windows 11 when available)
  • Surface Pro 7
    • RAM: 4GB, 8GB, or 16GB (LPDDR4x)
    • SSD: 128GB, 256GB or 512GB
    • CPU:
      • Dual-core 10th Gen Intel® Core™ i3-1005G1 Processor
      • Quad-core 10th Gen Intel® Core™ i5-1035G4 Processor
      • Quad-core 10th Gen Intel® Core™ i7-1065G7 Processor
      • Intel® UHD Graphics (i3)
      • Intel® Iris™ Plus Graphics (i5, i7)
    • DISPLAY:
      • Screen: 12.3” PixelSense™ Display
      • Resolution: 2736 x 1824 (267 PPI)
    • OS: Windows 10 Home
  • Surface Pro 7+ (for Business)
    • RAM: 4GB, 8GB, 16GB or 32GB (LPDDR4x)
    • CPU:
    • DISPLAY:
    • OS: Windows 10 Pro
  • Surface Pro 8
    • RAM: 8GB, 16GB or 32GB (LPDDR4x)
    • CPU:
      • Quad-core 11th Gen Intel® Core™ i5-1135G7 Processor
      • Quad-core 11th Gen Intel® Core™ i7-1185G7 Processor
      • i5 and i7 options with storage 256GB and above built on the Intel® Evo™ platform
      • Intel® Iris® Xe Graphics (i5, i7)
    • DISPLAY:
      • Screen: 13” PixelSense™ Flow Display
      • Resolution: 2880 x 1920 (267 PPI)
      • Up to 120Hz refresh rate (60Hz default)
    • OS:
Ref:
Intel® Atom™ x7-Z8700 Processor
Intel® Core™ i3 Mobile Processors with Intel® Graphics
Intel® Core™ i5 Mobile Processors with Intel® Graphics
Intel® Core™ i7 Mobile Processors with Intel® Graphics
Thank you! I wasn’t familiar with the Intel Atom processor, that greatly helps me narrow down my tablet possibilities.
Greatly appreciate your help @DanRathbun!
The more important part about the Surface vs the Surface Pro is that the “regular” Surface would only run Windows RT, a tablet version of the Windows OS which SketchUp is not written to use. The difference is as Dan showed, the x86 architecture on a Surface Pro allows the full Windows install which SketchUp can use.
Great news though! Microsoft has ceased production on the RT tablets moving forward, you can ONLY get a Surface PRO 4, so getting a current generation Surface will be the Pro version with proper version of Windows. Several people in the office are using Surface Pro 4 tablets and like them a lot.
The next question I have is about graphics. I know sketchup recommends a heavy duty graphics card, but I would assume that is for larger models and when working with renderings.
A large portion of 2-in-1s have Intel HD Graphics, would those suffice? Which series is the recommended minimum?
I ideally would find something with an Nvidia graphics card, but those up the price quite significantly when put inside a small device.
I think you just have to manage expectations when you’re buying a 2-1. You’re going to get portability and convenience at the expense of power. SketchUp will run on a system with an Intel video card but if you’re doing heavy production on hat system you may be frustrated with the power. That being said, it’s the perfect excuse to learn to model smarter so that your files are as efficient as possible from the start.
Here’s an old, but still relevant video from one of our 3D Basecamps on the topic.
I’m hopeful that the emerging handful of a high powered base that you can put your lightweight laptop into will catch on. The Surface Book seems more desirable to me than the Surface Pro for that reason, and the better keyboard, though the hinge is odd and seems like it’d break too easily. Again though, the Pro will do a decent enough job running light duty SketchUp work for demonstrations and smaller projects.
Just to slip in there, I run a Wacom Cintiq, it has become my main SU interface.
I use it connected to my desktop, then on it’s own in the pub or site. It is seamless for me as I work with stylus and 3d mouse. It ain’t cheap, but nor am I.
Hi
I’m pretty new to all this and it feels like an entire different language to me lol.
Could you help me please. I have a great computer in my office for sketchup but I need a tablet to be able to work from home (new mom here) and I have no idea what to get.
What exactly should I look for in a tablet?
Any recommendations and suggestions would be highly appreciated.
Thanks :slight_smile:
It’s an old thread, since then sketchup has released sketchup for iPad, and the sketchup web based app can be used on almost any device, when this thread was created there were only desktop versions.
If your workflow relies on plug-ins, you’ll need a laptop, either Mac or pc to be able to run sketchup pro, sketchup for iPad doesn’t allow the installation of plug-ins, it’s limited to the use of native tools.
Thank you. I noticed it was super old after I posted. I figured no one would even see it. Thank you for replying.
This thread was about detachables, which are thin notebooks with detachable keyboards so they can be used as tablets.
If you can afford them, Microsoft sells Surface and Surface Pro which run Windows and so can run Desktop SketchUp with extensions. The best ones for SketchUp will be those with Nvidia Graphics processors.
Compare Surface Pro, Surface Laptop, and all Surface computers - Microsoft Surface
I would not recommend any of the Surface Go line.
Very helpful thank you! I’ll look now.
