Question, the Plugin Welds was suggested to me. I looked into and found that SU2016 is not listed as supported. Please advise if you have successful experience with using in SU2016?
Yes. Weld works in SU2016. I prefer TIG-Weld which also works in SU2016. It is available from the Sketchucation Plugin Store.
didnât we do tig welding in high school, Dave? For the uninitiated, see http://www.lincolnelectric.com/en-us/equipment/tig-welders/Pages/tig-welders.aspx I guess I never pictured our TiG to be made of tungsten.
Is there any difference between Smustard and TIGâs versions? I never used TIGâs weld, wondering if it has more advantages?
Yeah. And some of the guys did other things they probably shouldnât have with the welder.
Itâs hard to tell by looking at him.
The key difference between Rick Wilsonâs Weld.rb and TIGâs TIG-weld, based on the description in Tigâs version, is that TIGâs doesnât close faces. I almost never want faces to close when I weld a loop of edges.
Smustardâs Weld always included the option to close faces. The latest version doesnât add a face by default - which is handy as I assigned this plugin to a keyboard shortcut as itâs used a lot. The option dialog is accessible through the Extension menu. .
By âclosing facesâ do you mean creating a face when a loop of edges is welded or adding a line segment to close an open loop? Because either way I never get any differences when tweaking the settings in Smustard.
If these Smustard Weld Settings are set like this, it never creates any faces.
I am on the same boat with @VahePaulman. always used Smustard Weld and never looked into TIGâs. Any other difference that you are aware of? Maybe both of us will convert
Thereâs no pop up dialog on TIGâs. Iâd forgotten about that on Rickâs.
Actually, I donât get the popup either.
I think once you set the setting, it doesnât popup.
I guess it it virtually the same as TIGâs.
Iâve nothing against Tig weld, but I have Curvizard Weld set as my shortcut, as itâs part of that whole package.
Thanks DaveR for answering my SU2016 question.
I also appreciate learning about alternative âweldâ plugins.
-Thanks for the discussion.
Smustardâs Weld doesnât have a pop-up any more like it used to. That option is now a separate item listed on the Extension menu.
