Weird Extrusion Results using Follow Me
Trying to use follow me to extrude a circle along a simple path and keep getting weird results at the corners… Any ideas? Have tried rebuilding both curves, grouping, using cleanup extension to no avail…
Try to scale 10x before extruding and you will probably solve the problem. After that scale 0.1x.
It should be because small segments in arcs.
Or, before follow me, make the path and the shape a component. Then move copy the component and scale it up 10x or 100x. Perform the follow me in the scaled version. The original will still be where you created it and should work properly.
It’s likely you have too many segments in your circle and arcs, and / or you are working very small.
