Hello, need some advice/help on the attached file. I’m trying to close the upper spaces on each door, but every time I try and delete the extra line, some walls disappear.
Bedroom.skp (2.4 MB)
Zoom in close. You can see that the edges of the walls don’t line up correctly. Here’s the outside of one of them.
An easier way to do this sort of thing is to draw the edges for the walls ignoring the doors. After pulling the walls up to height, cut the openings for the doors.
BTW, before you continue modeling, go into Model Info>Units and untick Enable Length Snapping. This contributes to your problems with edges not lining up correctly.
Make sure you are using tags correctly. All edges and faces should be created AND remain untagged.
And keep the model clean. No need to be hoarding unused components and materials.
Thanks @DaveR !!
Hey @DaveR thanks for the tips above. I made huge improvements in just a few days simply because I overcame this issue with edges, faces and so on - I even created an entire bathroom !!! ![]()
That looks great. I’m glad it helped.
