Hello, i’m new in this forum.
I’m trying to applying some materials using Vray and it’s not working well.
I’m following these steps to apply materials, first i select a material from SU the import the desired material from vray but it turns grey and if i continue to render the applied material is deformed.
Can somebody help me to solve this problem, is there something render settings or the followed steps are wrong.
I just uploaded in pictures the steps that i’m following to apply material from Vray to the selected object.
Step 01: I used the Paint Bucket tool in SU and apply a random material to the face i want to work on. It’s ok till now.
Step 02: Then I clicked on Vray Material Editor and Load Material (vismat).
Step 03: Here is the Material (concrete).
Step 04: Then apply material to the selected face (already has the UV from SU).
Step 05: When I clicked “Apply Material to Selection” the selected face turned black and somtimes grey with no material at all.
Step 06: Here is it, I cannot see the applied material …
Step 07: I continued to render the object, the material is totally deformed knowing that the object is a normal bloc with simple faces.
Any suggestions?
Thank You,
