Vray dome light is a type of light that you use while you are rendering a day light scene but you are facing a problem of low lighting render because you are not able attract more sun light into the scene , so you use vray dome light and place it anywhere within the scene or outside the scene it is going to give you the same result , it will bring the brightness in the environment inside the scene , it is just like in the real world during morning we can feel that we don’t need lights as it is very bright and in the night no matter how many windows you have in your home you will still require lights to brighten up your home …
Can you clarify? Do you have a question or problem using Dome lights? If so, please post a screenshot(s) of your render and settings with a clearer idea of what the issue is and someone on the forum will be happy to help.
