Hi all,
this is just a suggestion that I believe could breathe new power into sketchup:
Most 3d apps have some kind of visual programming in them. I don’t know if this has ever been discussed again but having used Rhino’s grasshopper for ages I often feel that it would be amazing to have a visual canvas within sketchup that would make it easy to handle dynamic components.
The mocap picture above is the equivalent of “onclick / animate(RotZ,0,60,90)”
You have a canvas where you can logically connect actions to dynamic components in the form of blocks. If you wanted to create a dynamic window next, you could just copy the door’s blocks, plug them in your window and have a new dynamic window in seconds without having to worry about syntax.
David Rutten, the creator of Grasshopper started it as a plugin for Rhino and now it has made it probably the only reason of its existence. A visual Dynamic component editor could possibly open new horizons for sketchups use as well.
just a thought…
edit: in the image, "click’ should be connected to ‘trigger’ and ‘0,60,90’ should be connected to ‘angles’ receptor.
