Hi, I have an issue with trying to set up a model to be used in Virtual Reality.
When the model is imported (as a GLB) into the Reality Converter Beta app on Mac. The model is there, however there is a pan&zoom issue. The model almost gets lost within the space and it is quite difficult to select the model to turn & zoom into it etc.
Is there a way to Anchor the model in a way for the model not to get lost within the space.
Is there a setting I need to add to remove the atmosphere/background space within the Sketchup file before exporting it as a USDZ or GLB file?
Any advice is much appreciated.
Try this file in Finder. It should manipulate ok. All I did was group your objects and move the bottom center of the group to the Origin, before exporting to USDZ.
When you have the Move tool selected, and you point at the object, you can tap the Command key to cycle through sets of grips. One of those includes a grip in the center of the bottom of the object. I clicked on that and dragged it to the origin.
Is there any chance you could take some screenshots of what you did please? As It I am not sure what you mean by dragging the grip to the origin? Thanks
Here’s a screen recording. After choosing the Move tool I then tapped the Command key, until I saw the control point appear under the center of the object, and then moved it using that control point, to snap it to the Origin.
Thank you for this it was really helpful! I am using a Windows computer so instead I tapped the CRTL button, but I don’t seem to have the control point that apears under the centre of the object like you had shown.
