Any chance of an instructional video of the process needed to create an exploded model with native tools for use in product plans? I’ve tried to come up with something but it always takes ages and doesn’t always look that good.
Cheers
Cheers
That’s a good idea.
FWIW, when I make exploded views it’s just a matter of selections of components and using Move to move them. Generally after an initial “exploding”, I create a scene and then tweak the placement of the components as needed. After a little practice it doesn’t take very long.
Thanks Dave, That’s sort of what I’ve been trying but it never seems to be very efficient and the end result never seems to look that good.
What kind of things are you modeling that need an exploded view?
I believe I have made a video like that a few years back… let me see if I can track it down.
I had that very same “old” video in mind.
So I played with creating a small exploded model with the help of that cube.
Then I thought: what if I trow in ‘Length Snapping’ set to 1” instead. To replace the 1” cube.
That also works quite well.
Very good video - Mihai showed me that you can use offset circles and other shapes the distance you want to explode in a similar way when you are exploding models too. For doors with hinges, you can open them using the rotate tool at the center of the hinge pin in a kind of exploding way. I know you know Aaron - just thoughts for a follow-on video.
Sorry for the delay Dave, life got in the way as usual. I’ve built a rising coffee table for my Son and a new workbench for the shop and a friend of mine has asked if I have any plans available for him to copy the designs. I manage to get something to him after a long session in Sketch and Layout but I’m sure that there is a better way than the trial and error process I went through. The Main reason for the exploded view was the rising action of the coffee table and the storage solution under the the workbench.
I did have a quick look but couldn’t find anything recent, hence my post so I would love it if you could create something fresher please.
Interesting idea I’ll have to give that a go. Thanks for chiming in with some useful thoughts.
Sounds intriguing but I’m not too sure what exactly you mean when you say use offset circles or other shapes unless you mean placing these at the distance you want to explode to with ever increasing distance from the origin of the model and using them as guides (I guess that’s probably what you meant but not sure) so I may try that too. Thanks for the ideas.
Yeah that’s sort of what I’ve been tryiing acheive but I think I left too much of the whole model in view rather than concentrating on the parts I want to more clearly demonstrate. My mate is going ahead with what I’ve sent him so we’ll see if the plans were usefull or if he has a nice bonfire sometime in the near future. ![]()
Thanks all for the suggestions and for resonding to my post. Here’s hoping that the maestro Mr D can come up with one of his extremely useful videos to show me the way (is that enough grovelling @TheOnlyAaron)?
Since you’re using LayOut you can spread out the exploded views into a few different scenes if needed. The one I showed is the base for a drafting table I designed for a client. There’s also exploded views for the drawer case, a typical drawer, and the top assemblies, as well as an option bookcase.
If you are using LayOut, another way to do this is to place groups on separate layers and isolate them in animation views. You can then compile the animation views in the layout page and add notes and dashed lines for connectivity references. This works best if you’re not using color (vector only).
I isolated a panel in one of my construction drawings and created a separate SketchUp file in which it was exploded, then manipulated the views in LayOut:
Thanks Dave, the more I think about this the more I realise I didn’t plan it enough before charging in and trying to throw something together for my friend. I’m going to have another go using your suggestions (and aothers on this post). I guess it’s the old adage ‘practice makes perfect’
Thanks for all the help.
Thanks for this, really interesting idea. As I said to DaveR above, I’m going to give it another go using the suggestions the learned ones on this forum have posted to see if I can get a decent process down for doing these exploded views in my plans going forward.
I have one I made years ago for a top bar bee hive. It’s just a matter of placing all the parts where they can be easily view and then setting up a perspective view/scene. I never really finished the exploded version because I built it and was happy so I just started building them for people who wanted them.
