How to fill a Vector List node ? I have 3 xyz to vector nodes that I want to use with ‘points to curve’.
I also tried Add item, but it crashes the graph.
Hello
I confirm that the “Add item” in the “Vector List” node causes a crash!
To create a vector list from your “xyz to vector” nodes you can use “Combine vector lists” then you connect it to your “point” node then “points to curve”.
Simon
Thanks for reporting team,
A fix is being worked on (but we are still spinning back up from the holiday period too).
