Undo the last operation
Hi,
After years of using sketchup I am just getting to grips with the online version, however there are one or two simple operations I can’t seem to find, UNDO being one of them, any help will be appreciated. Is there a “sketchup online” specific help file I can use.
many thanks,
Simon
Did you try Ctrl+Z ?
Buttons for Undo/Redo are at the bottom left in the statusbar:
Ah!
Brilliant, thank you
https://help.sketchup.com/en/sketchup-web/sketchup-web
This is also likely accessible from the (?) Help button next to the Undo & Redo buttons on the SU4Web stausbar.
i dont get the button at the bottom left corner, neither the option in the edit menu (and the shotcut is not working)…
is something to activate or to configure?
They moved them to be more visible
The Control Z shortcut is for Windows. As your profile says you’re on a Mac, the shortcut is ⌘Z (Command-Z) which is the standard Mac shortcut for Undo.
