Undo push/pull
Is there a way to remove walls that have been set to the ceiling height using push/pull? The walls interfere with the view of the room and furniture.
You can push the top faces of the walls down. If you push all the way to the bottom you’ll lose your walls entirely. Better option might be to use a section cut through the walls, though.
Or assign your walls a Tag so you can show or hide the them at will using the Tags pallet. Make sure the walls are contained as a group or component first (leave raw geometry untagged).
