Hello, we are interested in using the web version and “desktop app” for our school. (We’ve got the Microsoft Store version ready to be pushed out via Intune.) Neither our teachers nor our students can use the Sign in with Google option. For the desktop “app” which just looks like an edge wrapper or the actual site pulled up in a browser. It keeps saying that it isn’t enabled but we’ve followed the setup instructions from what I can tell. Our teacher email domain is “@palcs.org” and our student email domain is @stu.palcsmail.org" if those need to be added to a list to let the sign in function work.
Hi @nreiher, thanks for the post and sorry to hear that you are having difficulty with SketchUp for Schools. Your post is very confusing. SketchUp for Schools is a web based app. There is no desktop version of it. It can be deployed via either the Microsoft store or the Google store depending on what you use for your school. Once you deploy the app correctly, students should just be able to log in. If you deploy the app via Google, you may need to be added to our domain database, although this is not always required.
If you have different domains for students and teachers, you will need to deploy it for each domain individually. Deploying it for one domain will only allow users from that domain to use it.
Can you confirm you deployed the app via either Google or Microsoft correctly for both domains you listed and can you please let me know what you used to deploy the app? Also, once you do that can you please try loading it in Chrome and let me know if you get an error message?
I put “desktop app” in quotes specifically referring to the MS Store version. It’s just an Edge Web wrapper so not really an additional app. I’ve followed the instructions here - Setting Up as an Administrator And Google portion should be set up, but it is still not allowing us access.
It does this when attempting to sign in. Pop ups are enabled and it does this on a Chrome browser as well as the “desktop” MS Store version as well.
We have enabled the app in Microsoft and that works, but not all of our students have Microsoft Accounts currently, so we’d like to get the Google sign in working instead.
Ah, thanks for the clarifications. That helps a lot and I think I am starting to figure out what the issue might be. We still will need to do some additional testing though and I’ll need to ask an expert before I can confirm my suspicions but we are making progress towards a possible solution.
Can you confirm the domains you listed in your initial post are still accurate and that the students trying to access the app are not higher education students?
Gotcha. Let me know if there’s anything else we need to do on our end. Those two domains are still correct. We are a K-12 school and not higher ed. (I think even our Google OU for the students is marked as 18 and under, but it’s also not working for our staff domain that does not have that designation.)
Thanks again for the fast reply @nreiher. I just finished adding your domains to the database. It refreshes every hour so let me know if you are still seeing the error after an hour has passed or if it is working. Hopefully that was all we needed to do!
No worries @nreiher. I am happy to keep working with you. I am glad we are making progress and we can at least confirm that the app is working in the browser. That is a good sign!
I’ll ask our resident expert Tori once she is available and will try and find some other solutions while I wait for her. In the meantime, can you let me know if you are running any third party firewalls or other software that might interfere with the ability to connect to our app?
We do use iBoss as our web filtering and Sophos as our Antimalware. I checked the filter logs and it doesn’t seem to be blocking it and it doesn’t show as a blocked application for Sophos (which normally takes things out as they start, not halfway through like this).
Hello, I just wanted to check and see if there was an update. I tried it on both a student machine as well as my staff machine and am still getting the same error message when attempting to sign in with Google into the “desktop” Microsoft Store app.
