Hi, I have SU Pro 2021 with Vray 15.10.04, running on a MacBook Pro (2018) with macOS Big Sur 11.4
My problem is that I cannot dismiss the Vray Frame Buffer window. It is particularly annoying when I need to cancel a render. After stopping the render, I cannot close the window using the normal red window control (no response). If I minimise it, the whole SU window minimises with it, and if I restore it (from the Window menu of SU) then the frame buffer comes back with SU. If I try to move the window to the side it snaps back. After some considerable time, I will be able to close it with the Red window close button, but it takes ages before I can access the Sketchup window again.
It has persisted after a SU restart and a full system restart.
Did you ever find a solution to this please? (Old post) I just downloaded a trial version of V-Ray to see if I like it, but I am having the same problem. Sadly Twilight Render that I loved, is no longer compatible with the M1 -M3 chip with Apple computers. If this is going to be a problem though, that’s a total deal breaker. I can’t keep closing SketchUp because the buffer window won’t close! That’s crazy. Thank you.
