As soon as I open the render window for v-ray, there is no way of exiting back to the sketch up model. PLEASE help! I cannot minimise, exit or do anything. I am forced to Force Quit SkechUp entirely
You can toggle back and forth between SU and V-Ray Frame Buffer via the āWindowā menu.
You can also drag the corner of the V-Ray Frame Buffer to re-size (you canāt see my mouse cursor but I grabbed the bottom right corner and adjusted from there):
No I cant, it seems that when I am in full-screen mode in SketchUp, and I try open up the V-ray render window, it loses that entire top bar as well as the ability to go back into SketchUp and changing the screen size, even if using Mac Commands I switch back to the SketchUp window.
What happens when you are not in Fullscreen mode?
Sounds like the window isnāt full screen but floating and larger than the screen area.
Hi Lee, did you establish a cause for this as Iām now having the same issue.
Many thanks
Pen
Having the exact same issue ![]()
It does work if I use SketchUp not in fullscreen-mode and then open the V-ray render window
Hi there. Iām having this exact issue and I canāt see that it was ever resolved. Iām really stuck and need to exit hopefully without losing everything Iāve already done I sketchupā¦
help.
Hi there. Did Lee get back to you on this issue? Iām having the same problem. I canāt get back into sketchup and I really donāt want to force quit and lose everythingā¦
Same issue, Cmd W like Mike said above works for me.
Since this was my issue in Dec. 2023, and there is a fix, Iām posting for others, though this thread is quite old; dated April 2021⦠(it still comes up first in searches)
In vray 6 for sketchup, there is a setting under extensions->vray->preferences->parent frame buffer which is defaulted to ON. The setting is meant to keep the frame buffer on top of the sketchup window, but in full-screen, it screws things up by not allowing you to even touch the window ābeneathā.
Turn it off and your frame buffer will stop acting like a bratty teenager that doesnāt want to do what itās told.
Itās not mentioned as a Workflow change, but rather as a Footnote, at the very bottom of the page, in the instructions website. See here: Chaos docs footnote
Continuing the discussion from Cannot minimise/close window in V-ray:
Newly launched SU w Vray works fine, the issue occurs after several renders. Didnāt help āParent frameā OFF. Behaves like a bug, and not as a workflow function.
