I have spent hours trying to do the simple task of cutting an opening in a 6" thick exterior wall to insert a window. I have verified that the wall exists and is not part of the building volume. Using the Rectangle tool I create the opening outline. Then the Push tool to create the opening (hole in the wall plane). The cut opening is not created, only a box recessing into the model. Can anyone tell what I am doing wrong?
Hello. Make sure that you create your rectangle on the face of the wall. I think you grouped your wall and drew the rectangle outside the group. In order for the Pushpull to work, you must make sure that you’re inside the grouped object. If not, then share your model, so we can have a look.
The message window in which you are typing your replies to this thread.
When you hit Reply a window opens for you to type in. Look just above the text for the various icons, 7th from either end is the upload button.
When I attach the file “it will not send?” I tried up loading using the
“Sketchup Community” system.
Needless to say I am a novice at using the system since I seldom
participate, however my problem is such a simple issue that I am really
frustrated as to why I can’t get it to function.
It is surely something very simple. Seeing your model will let us know instantly what it is and help you get it fixed. I’ll send you a PM with e-mail address. You can e-mail the file to me directly.
The top floor is not grouped, so you can drawn an opening rectangle onto it directly, then PushPull that until a hole forms.
That ‘front’ wall is very thick ??
[Tip: set Model Info > Units to NOT snap to a length - otherwise this can mess with some PushPulling…].
The lower floor is a group so you need to select that group then edit it, then you can draw over its face inside the edit, and PushPull etc.
The PushPulled face needs to be in the same ‘context’ as the faces onto which you hope to add it and then punch with a hole…
The reply about the group is right-i made this mistake.
I try to remember:
right click, chose edit group. (and any sub groups or components in that group, after)
2.One must draw the rectangle on the face.
so I click rectangle tool.
then hover the mouse over the face until the little violet colored triangle or rectangle
shows and it says “on face”.
then i hold down “shift” and don’t let go, I assume to lock the inference.
Skp will also find endpoints on the face after this while you are holding the shift key.
I am new so I may be imagining all this. but it works for me.
Next to the win update that freezes sketchup this has been the most frustrating…
good luck
