Following along with sketch up for landscape and site design. However, When i go to geolocate I cannot change map type.
I have tried logging in and logging out again. Using SketchupFree on windows 10.
For the free version there is only one map type to choose. You would need SketchUp Pro if you want terrain or aerial imagery. If you’re doing landscape and site design as your work you need SketchUp Pro anyway because the free version is not licensed for that.
Thank you so much!!!
@DaveR is correct. Bu since this is a one-off lesson and is not for commercial purposes, see attached file with GeoLocation added. Note that there are many other parts to the course later on that may be challenging to complete with SketchUp Free…like using extensions for example which is a ‘pro-only’ feature.
CaytonCorner_GeoLocation.skp (2.8 MB)
I know that you need to pay for SketchUp Pro, but I do not know if it is worth it.
It’s worth it if you need the feature.
If you are using SketchUp for your work you need to be using a properly licensed version.
One small comment about what Eric and Dave said: It’s the web versions that only have the one map type, and not the Free one in particular. If you were to pay for the Shop version, you would still not get satellite imagery.
