Turning in final and frustrated with color distortion in scene
Hello I am trying to create a camera view of my sketch up model for a presentation. However, when I tilt the model in certain ways I lose some of the material. For example, the tile on the back splash over the stove is missing some parts its kind of streaked. Same thing happened with the refrigerator. Please help in desperate need and at my wits end and trying not to write sketch up off as a program I never want to use again.
it looks like you have ‘Z’ fighting…
this happens when two or more faces are in the same space…
it seems like your fridge is flush to the wall, and the wall has no opening.
the same with the splash back…
for a quick fix, move them forward a little, and it should stop…
then read up on how to avoid it in future…
Thank you so much I am trying this now
Thank you again I have solved the problem
thanks for reporting back…
your shadows seem a little harsh, have you looked at adjusting the Light/Dark shadow settings?
john
I did but I can definitely look at them again. What do you suggest?
without the skp I’m speculating where the shadows come from…
I’d want them a little softer and maybe change the time of day to move them around a bit…
the one that cut the floor/door/wall on the right of image looks a little odd…
john
Ok thanks again so much.
