TT_Lib2 error. Win10 64bit SU2016
Since using 64bit WIN10. I can not run the plugin TT_Lib2. Systems always error. Although I have tried to install all the latest updates. Even I had to reinstall WIN. Help me please. I am really very depressed during the past week. Thank you very much.
    **Error Loading File C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/core.rb**
**    Error: #<Encoding::ConverterNotFoundError: code converter not found (UTF-16LE to Windows-1258)>**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in `each'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in `to_a'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in `entries'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in `prepare_path'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/core.rb:127:in `<module:Lib>'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/core.rb:110:in `<module:TT>'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2/core.rb:20:in `<top (required)>'**
**    C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in `require'**
**    C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in `load'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2.rb:40:in `register_extension'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2.rb:40:in `<module:Lib>'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2.rb:14:in `<module:TT>'**
**    C:/Users/DanhNamArchitect/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>'**
helppppppppppppppppppppppppppppppp pleaseeeeeeeeeeeee
I’m sending you a test-version via PM. Lets see if that fixes this.
OK. Thank you very much. Your new version has run well.
Nice! I’ll release an update later today. Thanks for testing :smiley:
good luck for you
