I cannot get the PDF Importer from BrockWorks to load in SU 2026. It worked in my previous SU versions. I have attempted to reach John at BrockWorks, but I am not getting any replies. My license shows as valid through October 2026. I have tried reloading the extension from them. It shows on Extension Manager, but that’s it. It’s not functioning. Anyone else having this issue?
Any other PDF importers that work the same? I have a project in PDF for import, and I can’t start without this feature.
Thanks for your help and ideas.
DaveR
April 1, 2026, 8:42pm
2
I’ve not used the importer you refer to but SketchUp 2026 will import PDFs natively. Will that do what you need?
Maybe @jgbrock1 will get pinged and see your post here.
BTW, please update your forum profile.
hello! Sorry for the delay! I sent you an email and will help you get it going again.
I can guarantee the issue is that the new raster PDF importer SketchUp released in 2026 has a different FILE TYPE option. For OUR PDF Importer, you just make sure to choose file type PDF Vector Graphics and it works as usual. Sorry for the confusion! Email me if you have any issues, but this should take care of it - thanks!
Getting new error message that the extension failed to load.
Extension Errors Report
SketchUp: 26.2.243
OS: Windows 11
Ruby: 3.2.2
Extension: PDFImport (2.1.7)
Error: JSON::ParserError (unexpected token at ’
One moment, please...
.spinner {
-webkit-animation: spin 1s ease-out;
@keyframes spin {
0% {
-webkit-transform: rotate(0deg);
-moz-transform: rotate(0deg);
-ms-transform: rotate(0deg);
-o-transform: rotate(0deg);
100% {
-webkit-transform: rotate(360deg);
-moz-transform: rotate(360deg);
-ms-transform: rotate(360deg);
-o-transform: rotate(360deg);
#outer-container {
text-align: center;
#container {
display: inline-block;
height: 100px;
#text {
float: left;
height: 100px;
line-height: 100px;
font-size: 3rem;
font-family: "Montserrat", sans-serif;
font-optical-sizing: auto;
font-weight: 400;
font-style: normal;
padding: 0 .4em 0 .2em;
letter-spacing: 0.06em;
color: rgba(38, 122, 72, 0.86);
@media (min-height: 180px) {
#outer-container {
margin-top: 0;
@media (min-height: 360px) {
#outer-container {
margin-top: 5%;
@media (min-height: 540px) {
#outer-container {
margin-top: 10%;
@media (min-height: 720px) {
#outer-container {
margin-top: 20%;
@media (min-width: 1450px) {
.throbber {
width: 90px;
height: 90px;
float: left;
padding: 5px 0 5px 5px;
opacity: 0.86;
#container {
border: 3px solid rgb(38, 122, 72, 0.86);
border-radius: 51px;
height: 100px;
Loader
Please wait while your request is being verified...
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/RubyStdLib/json/common.rb:216:in `parse'
c:/users/north/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/pdfimport/activatable.rbe:161:in `check_result'
c:/users/north/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/pdfimport/activatable.rbe:34:in `licensed?'
c:/users/north/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/pdfimport/core.rbe:42:in `process_licensing'
c:/users/north/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/pdfimport/core.rbe:13:in `init'
c:/users/north/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/pdfimport/core.rbe:106:in `'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `eval'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `require'
C:/Program Files/SketchUp/SketchUp 2026/SketchUp/Tools/extensions.rb:209:in `load'
C:/Users/north/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/PDFImport.rb:13:in `register_extension'
C:/Users/north/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/PDFImport.rb:13:in `'
C:/Users/north/AppData/Roaming/SketchUp/SketchUp 2026/SketchUp/Plugins/PDFImport.rb:5:in `'
