Anyone out there have experience, using the Trimble Account Dashboard? Be good to chat if you have.
Reaching out again on this one…anyone using the dashboard. Any thoughts to share?
Yep! Quite a few people use it quite a bit! What questions do you have about it?
I would like to get in contact with other users of the dashboard
Manage your Subscription to SketchUp. In the browser, go to myaccount.trimble.com and log in with the email address you used to purchase the subscription. Choose the account under which it says “Purchased via reseller…” or the company account
You can also remove users again or change their role. You can also assign or take away access to a product again. Click on the three dots behind the user’s email address:
Deleting the Account Owner will not work, please contact your reseller. If you make a change, remember to save it at the bottom of the panel:
Make sure you’ve assigned a product in the Member area first! If you’ve given someone else access to the product, you’ll need to change that first so that the seat is freed up again. Then go to ‘My Products’ in the left part of the AMP:
Thanks Mike
I don’t get the column “Last Active” I get a column called “Satus”
Does anybody know why that is ?
There where some changes recently, was considered as a bug, but I don’t know the current status.
Why would you need that, btw?
You can monitor activities for individual projects in Trimble Connect.
Also check this thread:
Thanks Mike that’s useful info.
We don’t use Connect -
I thought I might be able to move around licenses if I knew who wasn’t using them much.
But I’ve recently learned that’s not allowed by Trimble, so I guess we’ll have to buy more.
