Hello! I am a bigginer in sketchup. I am using 2014 version. I was trying to draw a circle, but instead of circle it draws a triangle- echilateral. What have i done wrong?
Sounds like you changed the number of sides to 3. Select the Circle tool and without doing anything else, type 24 and hit Enter. Then try drawing a circle.
Hi folks.
Or you used the Polygon tool instead of the Circle tool and had the number of sides set to 3 the last time you used the Polygon tool.
Regards.
Jean
