Trees in library
I am a landscape designer, and have been enjoying sketchup with my hardscape designs. There are not a lot of trees, shrubs, and other plants in the sketchup library, and I really would like 3d. I believe one can purchase additional libraries. If anyone has a good source, please let me know. I realize some are free, and some you need to purchase. I also know these kind of objects can slow down my designs. I also am not sure once I find a good source, how to add this to my sketchup 19 pro.
Thanks.
DynaSCAPE?
No, I do not use dynascape Thanks for getting back to me.
hello,
have you simply looked in the 3d warehouse ? there are plenty of 3D trees… for free
here
(or inside sketchup window > 3D warehouse)
You may also can check:
https://sketchucation.com/forums/viewforum.php?f=40&sid=74956744d24281b99ce1e5a21353c5dc
For paid models, this may be worth looking into -
https://www.laubwerk.com/
I use laubwerk for trees but I think they only work as “proxies” and the tree will only be seen in its full glory inside a renderer… not sure if there’s a way to “explode them” so they can be seen in SU as a tree and not a cartoon proxy
Yes, only work with certain renderers such as Vray.
Laubwerk would be the right sort of quality for a professional landscape designer though (unless you don’t do any renders and rely mostly on SU and layout).
I second Laubwerk but as already mentioned, that requires a render engine such as VRAY or Thea to work. FYI - They don’t work with Enscape yet either. The short answer is that there is NO great one stop shop for good quality plants. High quality/geometry means for purchase and not in a SketchUp-friendly format and can bring most models to a crawl. That said, without using the "proxy-to-render engine’ method like Laubwerk or Enscape, you’re pretty limited to how many high-poly plants you can reasonably use.
Here are some various links that you may have already come across:
FormFonts 3D Models & Textures - this site is great but requires a paid subscription. The optimize 3D trees to work well with no render engine.
Redirecting... - this one is in development and we’re all eagerly awaiting it’s launch hopefully soon.
Soon to be released “Skimp” should make a lot of high poly models more easily importable to SU.
Yes. Definitely looking forward to that! Hopefully it will be released soon.
The most realistic plants with reasonable poly counts I could find in the 3D Warehouse are by Max Achkovsky.
Link to Max’s models page:
https://3dwarehouse.sketchup.com/by/dimax3dd?nav=models
If you scroll enough, there’s a whole section of “low poly 3D trees.”
Here’s a cool one!
I find the render times aren’t too bad as long as you don’t add any properties to the leaf’s render material like transparency, subsurface scattering, or something.
Very good link to an abundant provider of great Warehouse models.
Thumbs up to Max Achkovsky and by the way to you too Forestr!
