Toolbox in view menu
Hi everybogy! I start using sketchup but I couldn’t find the text menu on first row of view menu ( on top bar on the screen)
All tutorials I see they are using this toolbox menu who appears when opoened on the right side of the screen, meanwhile I didn’t the order to opened it in my VIEW menu. Could somebody help me on this issue? Thanks a lot!
Right-click on an icon, or View > Toolbars > Construction
Thanks ! … but I mean the first row on VIEW menu, I haven`t got this comand who open DEFAULT TRAY …and I don’t know where to found this, attached 2 pictures of an tutorial in internet, I haven’t got it :((
another image of the view menu
It’s not supposed to be in the View menu. As mihai.s shows, hover of the tray tab on the side to make the tray visible. If you want to keep if visible, click on the pin icon at the top right corner of the tray.
@Quimo La Ver > Barras de herramientas y la Ventana > Bandeja predeterminada son dos comandos que hacen cosas diferentes.
Para abrir la Bandeja predeterminada, use Ventana > Bandeja predeterminada > Mostrar bandeja.
Thanks all!, finally I found in a Forum that’s there are a difference between Ios and Windows, mnus are different so probably is this reason are some menus I miss.
Missatge de Quim Ferrer qferrer@gmail.com del dia ds., 29 de febr. 2020 a les 13:39:
Hola amigo saludos, quisiera saber cómo solucionaste el problema de la ventana de bandeja predeterminada
Hello!! Could you help me please to fix the same problem please
Esque no me sale nada de lo que me han dicho
ok, you’re on a mac.
on a mac you directly select all the individual panels, while on PC you create trays first.
Thanks for your answer🙏 but i can’t find layers and another’s tools, I don’t know. I really tried diferentes ways and nothing.
There haven’t been Layers in SketchUp in more than four years. Look for Tags.
What other tools?
it’s Etiquetas, 5th from the top in the pink rectangle I made. the translation in various language is not uniform, in spanish it’s tags as in “labels” while in french it’s like “html tags”
the extended toolbar on the left of the screen ? it’s in the “view” menu (just after file and edit), top choice.
Ahh they change the name!! Thank you so much, you solved​:pray::pray::pray:
