Hi
In Sketchup::Tool the “repeat” variable don’t work in def onKeyDown (key, repeat, flags, view) when the key is hold down.
After some research I found out (with help from a Dan Rathbun post) a way to work around the problem. I have tried to make a simple tool class to illustrate. If you push up or down arrow the size of the plane change
The code can be copy/pasted into the console
module RS_2020; end
module RS_2020::RS_TEST_SITE
class MyKeyStateClass
def initialize(getplanetool)
@getplanetool = getplanetool
end
def rsKeyDownState(keystatedown, key, view)
if keystatedown
@id = UI.start_timer(0.01, true) {
@getplanetool.rs_plane_zoom(key, view)
else
UI.stop_timer(@id)
end
end
end # class MyTestClass(keystate)
class GetPlaneTool
def initialize(model)
@keystateclass = MyKeyStateClass.new(self)
@model = model
@main_cplane_group = Sketchup.active_model.entities.add_group()
@yv_group = @main_cplane_group.entities.add_group()
@p_len_x = 50 # plane length x
@p_len_y = 50 # plane length y
@pt0 = [-@p_len_x,-@p_len_y ,0]
@pt1 = [ @p_len_x,-@p_len_y ,0]
@pt2 = [ @p_len_x, @p_len_y,0]
@pt3 = [-@p_len_x, @p_len_y,0]
@pt4 = [0,0,0]
@pt5 = [0,0,@p_len_y/4]
stipple = "."
@cline1 = @yv_group.entities.add_cline(@pt0, @pt1, stipple)
@cline2 = @yv_group.entities.add_cline(@pt1, @pt2, stipple)
@cline3 = @yv_group.entities.add_cline(@pt2, @pt3, stipple)
@cline4 = @yv_group.entities.add_cline(@pt3, @pt0, stipple)
@cline5 = @yv_group.entities.add_cline(@pt0, @pt2, stipple)
@cline6 = @yv_group.entities.add_cline(@pt1, @pt3, stipple)
@cline7 = @yv_group.entities.add_cline(@pt4, @pt5, stipple)
end # initialize()
def rs_plane_zoom(key, view)
@cline1.erase!
@cline2.erase!
@cline3.erase!
@cline4.erase!
@cline5.erase!
@cline6.erase!
@cline7.erase!
scale_factor = view.pixels_to_model(10, [100,0,0]) * 2
if (key == 38) # key up
@p_len_x = @p_len_x + scale_factor # plane length x
@p_len_y = @p_len_y + scale_factor # plane length y
@pt4 = [0,0,0]
end # if (key == 38)
if (key == 40) # key down
@p_len_x > 5 ? (@p_len_x = @p_len_x - scale_factor) : @p_len_x = 5 # plane length x
@p_len_y > 5 ? (@p_len_y = @p_len_y - scale_factor) : @p_len_y = 5 # plane length y
@pt4 = [0,0,0]
end # if (key == 40)
stipple = "."
end # def rs_plane_zoom
def onKeyUp(key, repeat, flags, view)
@keystateclass.rsKeyDownState(false, key, view)
end
end # onKeyUp
def onKeyDown(key, repeat, flags, view)
@keystateclass.rsKeyDownState(true, key, view)
end
end
end # def onKeyUp
def activate
# puts 'Your tool has been activated.'
end # def activate
def onMouseMove(flags, x, y, view)
@yv_group.hidden = true
ph = view.pick_helper
ph.do_pick(x, y)
face = ph.picked_face
plane = [0,0,1]
if face.is_a?Sketchup::Face
# puts face.plane
plane = face.plane
Sketchup.status_text = "Plane - (A: " + face.plane[0].to_s + "), (B:" + face.plane[1].to_s + "), (C:" + face.plane[2].to_s + "), (D:" + face.plane[3].to_s + ")"
end
ip = Sketchup::InputPoint.new
ip.pick view, x,y
ip = ip.position
point = Geom::Point3d.new ip
vector = Geom::Vector3d.new(plane[0], plane[1], plane[2])
angle = 45.degrees
new_transform = Geom::Transformation.new point, vector
response = @yv_group.transformation = new_transform
@yv_group.visible = true
model = Sketchup.active_model
view = model.active_view
refreshed_view = view.refresh
end # def onMouseMove(flags, x, y, view)
def onLButtonDown(flags, x, y, view)
ph.do_pick(x, y)
ip = view.inputpoint x,y
point = ip.position
plane = [0,0,1]
plane = face.plane
Sketchup.status_text = face.plane
@model.tools.pop_tool
end
end # def onLButtonDown(flags, x, y, view)
def resume(view)
# puts "resume: view = #{view}"
end
def suspend(view)
# puts "suspend: view = #{view}"
end # def suspend(view)
end # class GetPlaneTool
SKETCHUP_CONSOLE.show
SKETCHUP_CONSOLE.clear
puts "Use Up or Down key to change size of plane"
# *** Create sphere start ***
entities = model.active_entities
centerpoint = Geom::Point3d.new
vector = Geom::Vector3d.new 0,0,1
vector2 = vector.normalize!
edges = entities.add_circle centerpoint, vector2, 100
face = entities.add_face(edges)
vector = Geom::Vector3d.new 1,0,0
edges = entities.add_circle centerpoint, vector2, 5
face.followme(edges)
# *** Create sphere end ***
tool = GetPlaneTool.new(model)
model.tools.push_tool(tool)
end #module RS_2020::RS_TEST_SITE
