In Windows, if press UP key code prints 38 but in MAC prints 63232.
In Windows, if press alt key code prints 18 but in MAC prints 524288.
In Windows, if press Tab key code prints 9 but in MAC prints nothing.
Are codes in MAC unique? In all Sketchup versions, MAC always prints 63232 for the UP key or not?
Thank you in advance for your help.
As Curic sayd the best way to utilise keyboard events to use the build in constants described in a #onKeyDown method. (Sure you can use it in #onKeyUp too)
VK_ALT
VK_COMMAND
VK_CONTROL
VK_DELETE
VK_DOWN
VK_END
VK_HOME
VK_INSERT
VK_LEFT
VK_MENU
VK_NEXT
VK_PRIOR
VK_RIGHT
VK_SHIFT
VK_SPACE
VK_UP
This give you a relative “bullet proof” solution for both OS… well with some restriction e.g some of them may not respond on onKeyDown, In that case you may use the #onKeyUp.
If you need some additional key you have to be careful, because the user can define a shortcut (you know in Skecthup Perferences/ Shortcuts) winch will have a priority.
E.g. If you will define tab key in your extension, but the user set it to do globally in SU, your code will not get the tab key event, but will be deactivated.
Still if you want to use other keys, one way to do it to define a constants in top of your code e.g.
BTW.
My own conclusion - studying the keys - ended up to avoid use other keys than the following keys in my plugins:
VK_CONTROL
VK_SHIFT
VK_DOWN
VK_LEFT
VK_RIGHT
VK_UP
VK_ALT
One more advise:
In #onKeyDown, and #onKeyUp :
Return true to prevent SketchUp from processing the event.
e.g.
def onKeyUp(key, repeat, flags, view)
if(key == VK_ALT)
# do something
return true
end
end
def onKeyDown(key, repeat, flags, view)
if(key == VK_ALT)
# do something
return true
end
end
Thanks again Dezmo. VK_UP can use in both Windows and MAC OS. Using it, we don’t need to worry about key numbers in MAC OS, which is great. It seems we don’t have VK_ESCAPE or VK_TAB. ESC key has the same code on both platforms and it seems better not to use TAB Key on both platforms.
No, it is not. It seems Tab key in MAC control by OS and has different usage. I think we’d better forget using the Tab key in MAC OS and let OS use it.
Fortunately esc key is only a key in both platforms and we can define its usage. For example to draw a wall user can select several breakpoints. I used esc key to delete last breakpoints and it work same in both platforms.
Okay.I just wanted to get your attention.Please check the 3 snippets.
You can implement to the onKeyDown to listen for ESC, but in the onCancel method is already there.
if( key == 27) #ESC key pressed
delete_last_brake_point()
end
end
def onCancel(reason, view)
case reason
when 0 #ESC key pressed
do_my_chancel_stuff()
when 1
# do something
when 2
# do something else
end
end
this will do the same as above:
case reason
when 1
# do something
when 2
# do something else
end
end
BUT
When onKeyDown is implemented and returns true, pressing Esc doesn’t trigger onCancel.
return true
end
end
case reason
do_my_chancel_stuff() # this will not happen
when 1
# do something
when 2
# do something else
end
end
