I’ve got many small parts in my sketch, designing some unit. With each part it gets more laggy since it needs to render it all. I can not find nothing via google regarding freeze option that simplifies geometry. Is there something for this ? Got a lot of things to add…
Hi,
Without seeing the file, it’s hard to tailor an answer. but here are some general ones :
Profiles. profiles are lines that mark the outline of the objects / groups, not simply a face limit.
Because of that, profiles require constant rendering, move a bit and the outline changes.
In menu view / line style / turn off profiles (or in the Style panel). it should feel like quite a boost, on my machines, after testing a few files, about 20-30% performance boost.
If you have a LOT of small elements, each in their group / component, it means each of them has its own outline, therefore it has its own profile.
you can see why it’s good. -
shadows. if you have them on, don’t. simply that
manage visibility using tags and scenes. You say you have many many small parts, but do you need to see ALL of them all the time ? you could maybe create a tag or two to hide stuff you don’t need at the moment. it can be temporary, just here to allow you to work efficiently.
Thank you, I’ll try just that.
