TEXTURE POSITION using arrows
As you probably know, you can face certain problems if you have the geometry placed very far from the origin (changing the position of the axes does not influence) or in the case of plugins, it is necessary to be placed in a certain direction, and when I faced a problem that seemed strange (as was the case with your texture modification, which worked in the same model for one geometry and not for the other) I also discovered that positioning in the area with + can be a solution.
Anyway, I draw starting at the origin (0,0,0) to the right and up (the positive area).
