Texture Position Horizontal
Texture position with the blue tack will allow me to “resize” or stretch the image vertically, but what do I do if I want to stretch it horizontally? There seems to be no way to do that.
Thank you
You can use the green push pin and drag it out away from the center of the protractor.
Or, you can right click on the texture again and delselect Fixed Pins. Then you can drag each pin independent of the others.
THANK YOU!
You have no idea how much time and frustration this has saved me. I usually try to size my textures to what I am applying them to prior to importing to the materials panel, but sometimes that does not work out as planned. Just a small tweak needed and so this is much faster.
Encore - thank you.
Kathryn
