Hello, I’m experiencing clipped text upon PDF export from LO 2022.
Interestingly this does not occur when print as PDF by Adobe Acrobat.
Attached are example of elevation & section drawing cropped in 100%.
Seemed this issue has been addressed in few years ago, I need solution asap.
I see the issue. You have line spacing set to 7 which is too small for the font at that size. Set it to 9 at least and the text won’t be cropped off. That font seems to have a lot of padding on the top, though. A different font might allow you to tighten up the text more. Your spacing of 7 works fine for the lower case letters but it’s too tight for capital letters and numbers.
