Template was change when loading the model in another sketchup
Hi All,
I made a model and by default it gives the surfaces as white.
when I load it into another SketchUp I got a cream color, and it changed the white color in the model to the cream color.
It is like I chose Architectural-millimeter template instead of Simple-meter.
how can I change to the white again?
How did it happened?
why should we need from the beginning the cream color? is there any benefit from it?
thank you.
Look at the In Model style in the Styles panel. What style is selected? If you imported the model into a different SketchUp file or copied it and pasted, the model will appear using the selected style of the new SketchUp file, not the one used in the model when you saved it. Either edit the style or select a different one in the Styles panel.
Thank you!
I miss this part.
it works.
You’re welcome.
If you’re concerned with the dimension units, also look at Model Info>Units. Change them if needed and if the box is ticked, untick Enable Length Snapping.
