TC > Share a Link... in SU2024
I want to share a non-editable model view link, but I want to keep my master file on my local hard drive. Is it possible to use the “Save a copy to TC” option and share that file?
I get the impression that using the “Share a link” option from the file menu forces you to place your master file in the cloud. Should I be creating a local copy SU file and be sharing that instead?
Save your file locally and then also save it to TC. You can share that link and still continue working on the locally saved file as the master. Each time you save it to TC after the first time it will be an incremental save so you can go back to an earlier version, too.
If you want to continue working on the locally-saved copy immediately after saving to TC, go to File>Open and open the local one again.
You can also use Save a Copy but each time you use that with the file it’ll create an additional copy of the file. If you have to share it more than once you’ll have t o keep track of which copy you are sharing.
