Hi Guys!
I have a object i want to turn an object upwards and it won’t work because the rotate-tool isn’t switching to the dimension I want. Is there a key combination for switching through the dimensions?
Thank you very much in advance ![]()
Do you mean you’re having difficulty getting the rotation direction set correctly? First, you can orbit to a view point that makes it easy to set the rotation direction. You can also use the cursor keys to set the direction.
Tap an arrow key to change rotation axis.
Blue - up arrow
Red - right
Green - left
Selected plane - down
PS. As usual, DaveR gets there first.
Thank you ![]()
Thank you too ![]()
