Hello. It seems as though the SVG outline plugin doesn’t work on the Mac version of Sketchup Make 2016. I have the latest Mac OS X. When I click the save button nothing happens.
It does work on a Windows 8 laptop, but unfortunately right now I dropped that laptop and cracked the screen so my Macbook is the only option. Another person also verify this was not happening for him also.
I would guess that you might get almost similar results by printing to PDF with the Vector Printing option enabled, and then using one of the zillion available free converters or a graphics application (Inkscape is a free one) to convert the file.
John, which developer forum are you referring to? I couldn’t find it…
Also the 1.2 version I found at the link you provided still doesn’t work for me - it says it has exported, but nothing appears. I believe that there are still multiple errors in the webdialog’s html that cause javascript to throw (silent) errors and fail. I’m working on sorting them out using the WebKit inspector (I got the old version working that way…). There is also a confirmation dialog that “underpops” the main view when you save. You can’t see it on Mac unless you move the view aside!
I have a modified version that now works on Mac. Turns out it only needed minor fixes. However, the discourse software won’t let me upload it here! If anyone can’t get the official version to work and would like my patches, PM me your email and I’ll send the files to you.
The easiest is just the .rbz file. For SketchUp 2016, install using Preferences->Extensions->Install Extension. I have not tested this on SketchUp 2017 as I don’t use it myself, though off hand I don’t see a reason why it wouldn’t work.
HI Steve,
I’ve installed the extension in the latest version of Sketchup(non-pro
version) and it won’t save/convert the file/drawing I’m trying to
save/convert. I click on the save button and nothing happens. I’ve
uninstalled and reinstalled a couple of times, restarted the computer a
bunch of times and no joy.
I agree, extensions should, and are, be super easy. I just can’t get this
one to work properly.
Hi Steve,
I tried using the Ruby console to see what, if anything, is happening when
I’m trying to use SVG. Nothing pops up on the console, it’s like SVG opens,
looks like it will work, but nothing happens. Nothing generated on the
console. It just seems to be dead.
I’m having the same issue as above where I click “save” and nothing happens, the button is just clicked and un-clicked. I’ve read the replies, still not sure what the fix is. Any idea how to resolve? I tried the same version as SirPoonga above. Had trouble installing John_drivenupthewall’s linked version.
Recently on Sketchucation someone posted about having difficulty getting SVG files. I suggested adding .svg to the file name which worked for them. Evidently the exporter doesn’t automatically append the extension. Maybe the same issue here?
