Hi all,
I’m a newbie here so be kind with me
I want to convert a sketchup drawing into an svg-file so I can use it on a Festool Shaper.
Any help here would be nice.
Thanks so much
Christof
Search the Extension Warehouse.
Please complete your forum profile with operating system and graphics card model.
I get this message when I search for it
There are three other options but you could still try the one you selected. It may work even though it isn’t marked to work.
I did installed it but how can I now save as svg file?
Thank you so much for the help
Read the description for the extension and follow the links as it directs.
You could install Open CutList instead. It is also currently supported.
i cant seem to find the signs (or knobs) for svg file like a do on cutlist?
I don’t understand what you are having difficulty with. Which extension are you using?
i v downloaded the extention but how can I save the drawing now as an SVg file?
Which extension?
In OpenCutList click on the Export button in the toolbar and choose Export 2D Part.
Read the documentation for the extension which is available from the extension’s Extension Warehouse page.
extension is facesvg
I v found the picture on the export from cutlist that you send but how do i save then?
well there is a step by step video
Why don’t you read the instructions that are given for OpenCutList?
i cant seem to find the instructions anymore
But when I try to do the same as in you’re video, it dont work for me
Go to the OpenCutList page in the Extension Warehouse. Click on the link for Documentation.
So you must be missing a step and not doing exactly what I showed.
i v looked at the instructions of cutlist Great tool But no extra info on savind as a svg file
Good ,morning Is it possible that I cant make an svg file ,because the drawing is “flat”? I v imported it to sketchup from an AutoCad file But I don’t seem to be able to push/ull the drawing?
I put the drawing here so you can see
tekening ovalen klankgat OM.skp (1.1 MB)
Thanks so much for all you’re help As you already know by now, I’m not so good at the drawing with pc. Thnank you
