Hello everyone! Not sure why I have such an surface issue … any advice?
It is not totally clear what the issue is that you are talking about. Plus you are showing two different parts of the chair in your two images. Can you explain what you are hoping to see and what it is you are seeing, instead?
To me it looks like the edges between the faces in the curved part are hidden, not smoothed.
Adjust the softening angle: V-Ray will use these edge normal values to fake the edges to be less faceted.
You need to restart the render for the new geometry parameters to kick in - they won’t change mid interactive render
Thanks man!
You’re welcome. Let us know if that did the trick.
