Stone bar design
Hii does anyone know how i would re create this stone cast effect on my sketchup model. thank you
If its going to be used as an asset I would create a Texture and apply it to the surface. If the bar is the main object I´d model an stone and use Flowify to wrap those stones around it, including the joints.
Hi, I am trying to use the flowify tool but it isn’t working and I don’t know what i am doing wrong. if anyone knows how i could fix this please.
Have you seen tutorials of flowify? You must first, have a quad mesh group, then create a plane and group it, then two lines connecting the vertices of the plane and the mesh, that should also be grouped, then group those 3 elements, to se if it’s well done, select the group, go to extensions, flowify and impose grid, it should subdivide the plane with the same amount of the quads of the mesh, then you can model the object that’s going to wrap the main mesh on the plane, that object must be a group without nested groups or components.
If you want, you can share the file so I can check it and make a video showing you how it should be done.
thank you i managed to figure it out.
