Hey!
Short question: Is it possible to export STL files with the “SketchUp Shop” version and use it in the Physibel software “Solido” or do I have to use “Sketch Up Pro”?
Thanks in advance!
Did you tried?
Thank you!
I can’t try if it is possible to import the STL correctly in “Solido” because I have just the demo version. In the demo version of “Solido” the function “import” is not possible.
I thought that possibly someone also works with these two softwares and could speak from experience.
Their website says “it’s compatible with STL-files” so I guess it should work…
You could always ask the people of Solido to test a sample file for you.
Thanks! Good idea! ![]()
