TFSOG
1
Hi everyone, hope you’re all well.
Just wondering if it’s possible when ising the Stamp tool to set the offset to be 0mm so that it gives you perfectly vertical cut lines?
I have tried several times but it keeps defaulting to 25mm.
Not a huge deal as it’s barely noticeable but I like clean and straight lines so just wondering if there’s a solution or something I could do?
Thanks and best wishes.
Window>Model Info> Units
Disable length snapping…
TFSOG
3
Many thanks for the reply, unfortunately that doesn’t seem to work? It’s still got an offset of ~25mm.
I’ve as attached the .skp in case it’s me and anyone has 2 minutes to check.
Thanks again.
bmike
4
I gave up on the stamp tool and make the terrain a solid and then subtract the foundation.
TFSOG
5
Great shout, never thought of that! Thanks mate.
